주요 콘텐츠로 건너뛰기
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
20 질문 전체 보기
Non-responsive with battery connected
Have a strange issue. My elite 2 controller is completely non-responsive when the battery is connected. Won't power on, charge, or anything. BUT it works when plugged in via usb without the battery connected. As soon as I reassemble the back plate and connect the battery, the controller is completely dead.
Useful diagnostic info:
  • battery is delivering power and not damaged
  • no liquid damage to controller
  • no visible corrosion on battery connectors
What is going on????
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Are you using a battery pack? Or just 2 AA batteries? Did you tried both to test the controller? Is the controller up to date? When using a battery pack, which brand? The one from Microsoft?
This is an elite series 2...the battery is built-in, not AA replaceable. The battery is original.
댓글 달기
답변 1개
가장 유용한 답변
Hi Matthew! Sry! Okay the easiest thing to try is a new battery pack and see if that solves it! If not, it’s motherboard related. Controller is up to date?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
The controller is up to date. I just put the controller back together and while securing the back plate onto the board housing the controller turned on. Once I screwed the back plate onto the housing completely, the controller is now no longer responsive. Could there be a faulty or loose connection? The three pin battery terminal doesn't appear damaged.
Thoughts?
Hi! Could be, or something is causing a short. Can you check if the screws are not touching the motherboard? Also check the cables to see if they are free when closing the back plate.
댓글 달기
답변을 추가하세요
Matthew Riordan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 66
