주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
No Network Coverage problem
Why do I have no network coverage?
I'm pretty sure the phone is properly unlocked and i put my sim card in and activated it on my
이미지
phone plan and no matter where I go (places where on other phones i get great coverage) i get no signal, the simcards network providers are being detected but the network bar is always empty. Is this an issue with the phone, the carrier, unlocking, or just a bad antenna? what do i do to fix the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 4개
Hi @samxo247
Can you try a different provider's known working, compatible SIM card in the phone to check if it is unlocked on not?
의 공유
@jayeff Thanks Jayeff, the phone is unlocked, I've tried different simcards of different providers but the result was the same
의 공유
@jayeff yes it was working at first, this happened after resetting the whole phone system, and I have tried the network resetting just now, it didn't work
의 공유
My phone it's not working any sim card it's oppo a74 5g
의 공유
댓글 달기
답변 2개
가장 유용한 답변
Hi @samxo247
Has the phone connected and worked OK before?
If you haven't already done so, try a network reset and check if that resolves the problem. Here's a video that shows what to do.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
@samxo247
Did you factory restore it with the SIM card inserted?
If so, remove the SIM card and factory restore it again. Once it has fully restored, insert the SIM card and check.
의 공유
I try all of this
의 공유
댓글 달기
Phone ki body change and network issue
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sam XO247 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 54
전체 시간: 1,504
