Piano won't start
Piano is completely of and won't come on
좋은 질문입니까?
@adolphussbeah always start buy checking your AC adapter. Make sure that it has the proper output voltage and that the connectors are both in good working condition. If it is, then I would suggest you precede by testing the voltage on your DM board. Follow the flowchart and test the points to make sure you have the voltages.
To help you to get to those boards. we will need to actually see your piano. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 500
댓글 1개
Hi @adolphussbeah
Have you checked that there's 12V DC on the output plug of the power adapter used to power the piano or tried using another known working compatible 12V power adapter to see if the piano works?
What have you tried?
jayeff 의 공유
