주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skullcandy Hesh 2는 Skullcandy에서 판매하는 블루투스 무선 오버이어 헤드폰입니다. Skullcandy Hesh 2 모델은 모델 번호 S6HBGY-3xx로 식별할 수 있습니다.
Sound too low on bluetooth mode.
The sound on bluetooth mode is too low but when i connect it with a wire it give normal sound. Tried different devices but insisted on the same problem.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@syedalam81869 since everything works as it should, except the volume, I suggest you try a new battery. This of course is never easy since they (manufacturers) do not want us to fix things. With these headphones it’s fairly straight forward. Basically, you remove the earpads. After that, remove the four screws that hold the driver to the housing. The battery is behind the speaker nestled into the headset. I suggest you check this video (it’s dreadful but has a bit of valuable information on how to remove the drivers (speakers). Use this document Internal Photos 2316351 for the rest of it. The second picture shows you the battery etc.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
syed alam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 178
