주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-84 Plus 계산기 지원.
Calculator seems to be unresponsive
My calculator turns on and shows the ram cleared after turning on and then when you try to input anything the cursor just gets stuck and hangs. Nothing happens after that. it is unresponsive and does not responds to any input given and just stays blank. i have removed all the five batteries and replaced but still the same. when i try to connect it with my laptop it not being detected by the software.
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
are you saying some of the keys work and it locks up after hitting those keys?
의
no after hitting the on button it locks.
의
댓글 달기
답변 1개
Check the I/O port for any debris. Sometimes dirt will confuse and freeze the calculator.
You can try an OS reinstall. Take out one battery then hold [Stat] while putting the battery back in. It should say something like 'send OS new' or 'waiting for OS'.
Now plug the calculator into your computer using the USB cable and send the OS. You can download it from TI's website or directly from TI-Planet: http://ti-pla.net/a2111
It will take a few minutes to install.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Yunus Panthodi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 29
전체 시간: 401
