주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
본 제품은 Original Nintendo 3DS, 3DS XL 및 2DS용 추가 액세서리로, 독점 캐릭터, 아이템 및 기능을 얻기 위해 Animal Crossing 및 Super Smash Bros.와 같은 게임의 amiibo 피규어/카드를 읽고 쓰는 데 사용됩니다. "New" 3DS/2DS 기기에는 amiibo 지원 기능이 내장되어 있어 해당 기기에서는 이 액세서리가 필요하지 않습니다. 부품 번호는 CTR-012 입니다.
Converting to Rechargeable Batteries
How would one go about converting the 3DS Amiibo reader into a rechargeable battery unit rather than one that uses replacement batteries?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
@kytim899 you would need to fit a charge controller as well as a battery housing. It runs on what, 2 AA batteries. Then it is most likely a 3V 2600mAh device., That means you might get away with using a single 18650. You'd need a resistor setup to drop the voltage to 3V since the 18650 is 3.6V. For your charging controller you'd need something like this
By the time you have it designed, have all the parts you need and made sure it fits inside the Amiibo reader you might realize that purchasing rechargeable external batteries and charger, something like this, might just be a lot easier. Now, if you are wanting to give this a try, let us know. I am certain there are lots of good people on here that will help you all the way.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I was thinking about connecting a charging board to a rechargeable phone battery that is two AA batteries with 2.7V and then connect that charging board to the motherboard of the Amiibo reader.
Considering how expensive these readers are at the moment and the amount of work needed to convert it to rechargeable it might be better to just consider this an experiment.
의
@kytim899 absolutely. It would be a fun thing to do. Just a bit costly and only if fun if you have a spare unit to mess around with,
의
댓글 달기
답변을 추가하세요
KYTim899 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 370
