주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 3월에 출시된 4인치 iPhone으로, iPhone 6S와 유사한 하드웨어 사양을 갖추고 있습니다. 실버, 스페이스 그레이, 골드, 로즈 골드 색상으로 제공되며 16/32/64/128GB 저장 용량 옵션이 있습니다. 모델 번호: A1662 및 A1723
New screen replacement not working
Replaced my screen with digitizer from IFIXIT website. SKU: IF327-011-3
I have installed the new screen but not getting an image or light on the display. When I install the old shattered screen it works perfectly fine.
I assumed it was a bad connector as they don’t click nicely as the original, so I swapped the back plate so I can use the old connectors with the new screen. Still no image.
I switched everything back to the original shattered screen and it works. Is this a screen defect? What should I do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi, normally you are expected to test screen operation before installing, so if there’s an issue you can get replacement.
But because you swapped the back plate over you might have replacement denied, however it costs you nothing to ask.
Otherwise you’ll just have to buy another and test before installing.
의 공유
댓글 달기
답변 1개
가장 유용한 답변
iFixit has a lifetime warranty on their screens, and to my knowledge there's no restrictions on having installed the screen or not, so you'll definitely want to get in touch with their support people to see about getting a replacement. Best way I've found was to email them at support@ifixit.com.
Sorry to hear that happened to you; iFixit is well known for carrying quality parts but no matter how careful you are, there's always going to be that 1 in 10,000 that was born bad. I've always had great service from them so hopefully things will go as well for you.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
DeCePtICoN1981 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 196
