주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
팝콘 머신 및 팝콘 조리기 수리 안내서입니다.
Popcorn machine mains problem
A popcorn kettle on the bench. It was reported to trip mains fuse. When testing it I measured 1.3 kW. But kettle was marked 500 W. I opened it up and could not see or measure anything faulty. Cables and grounding was good. But there were rust on the thermostats nuts. I cleaned the nuts and rusty residue on the thermostat. Put everything back together and now the kettle measure 500W and the thermostats works. Is it possible that the thermostats was faulty due and the reason for it to draw 1.3 kW instead of 0.5kW?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@seafoamgreen absolutely. SInce everything is looking like it is in good working order, and it does not pop the mains fuse, I would say you got it fixed. Could be bad thermostat, bad connections corroded connections etc.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sea 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 391
