주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년에 출시된 Sony Cyber-shot 디지털 스틸 카메라 W330 모델입니다. 1410만 화소, 4배 광학 줌, 3.0인치 LCD를 탑재했습니다.
Why is my screen white?
So, I cracked my LCD a while back so I ordered a replacement off of eBay. I just replaced it, and I was testing it and the screen is white. When I turn my camera on, the lens opens but then retracts and the screen stays on. I was pretty gentle when I was replacing it, and the only reason why I replaced the old LCD was because it was cracked.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
Just tested my old LCD and it doesn't turn on at all. I'm guessing I messed something up >:(
@ellasimones not necessarily. Try you new screen again and see if it still shows white.
@oldturkey03 tried it as well and same thing :(
댓글 달기
답변 1개
@ellasimones so it remains black no matter what (old or new screen)? The white light means that your LCD receives the backlight but no video signal. So you'll have to check the connector where the LCD plugs in and check for bend, broken, corroded pins etc.
The backlight and the video have separate circuits. For the video processing you would have to check the IC201 which is the signal processor on the on the SY-243 board.
Basically what you want to do for now is to disassemble your camera and check the board for anything odd (missing or burned) component.
You can always post some pictures of that board with your Question so we can assist you with that. 기존 질문에 이미지 추가하기
Also, you can now download the Level 2 and Level 3 SM from the bottom of this page Sony Cyber-shot DSC-W330. It'll help you with finding the components as well as trying to fix it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ellasimones 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 46
전체 시간: 694
