주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색. 이 페이지는 사용자가 iPhone 4 문제를 진단하고, 수리하고, 도움을 받을 수 있도록 돕는 것을 목표로 합니다.
How to Install Itunes For iPhone 4 .
How to install iTunes on iPhone 4 device. And how do I install it? And can i install myself.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 7개:
To be clear, the iTunes app itself isn't appearing on your device?
This question is really vague. Like it could mean what version to install on Mac or P.C to connect the phone for certain exploits or anything 🤷‍♂️
@muhammadsa29369 We prefer you not hold private conversations with our contributors, as the purpose of this site is to help others. As such, any assistance you get in private helps you and only you, whereas posting a question on this site allows everyone to benefit from whatever you learn.
@muhammadsa29369 use this guide 기존 질문에 이미지 추가하기 to add pictures to your Question.
댓글 2개 더보기
댓글 달기
답변 2개
iTunes is installed by default when you got your phone. Did you remove it somehow?
Depending on the version of iOS you should be able to see it looking at the icons it’s a Purple box with a White five point star in it. You can also go into search and type iTunes to locate it if it’s not visible.
If you removed it you’ll need either use this to access it via the iPhones Safari web browser How to Download built in Apple Apps for iOS from the App Store. Or connect your phone to a Mac system with iTunes to re-install it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
@muhammadsa29369 not sure why you would want to install iTunes on your phone. You do not need it to play music. For that you use the innate App "Music". Where you do need iTunes, is on your computer. You use that to sync your iPhone with your computer, not the other way around. Remember, your iPhone cannot be upgraded with anything above iOS version 7.1.2
Do not get confused with the iTunes Store App, which uses a purple box with 5-pointed white start in it, as icon. That is not the iTunes you need to sync your music/files :-)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Muhammadsalim Mamadaliyev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 36
전체 시간: 729
