주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
주로 심판용으로 사용되는 무선 통신 장치입니다.
Loose connection inside the rectangular rubber-coated case
Where would I start if I wanted to take this apart and re-solder it? Obviously would prefer to avoid any permanent damage. I've tried sliding a knife around the edges (there's a slight ridge where what appears to be two halves were pressed together), but I'm guessing I need heat and/or some kind of solvent. Anyone have experience taking apart weatherproofed / sealed electronics?
이미지
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
@miketexter post a couple of well -focused images of the "rectangular rubber-coated case" with your Question. that way we can see what you see and hopefully assist you further. 기존 질문에 이미지 추가하기
의
@oldturkey03 done, thank you for that tutorial :)
의
댓글 달기
답변 1개
가장 유용한 답변
@miketexter that looks like it's very well glued together. If this would be mine, I'd take an exacto knife (or a razor blade) and cut through the seam. After completing the repair, I'd use some silicone rubber glue to reassemble the case.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mike Texter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 188
