주요 콘텐츠로 건너뛰기
Released 2010 RAM: 4 GB Hard Drive: 500 GB Processor: Intel Core 6th generation i7-6300 @ 2.80 GHz GPU: Intel Q43/Q45 Express Chipset Graphics
5 질문 전체 보기
Why is my desktop beeping twice and won't display
my desktop beeps twice and won't turn on or display.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
There are LED light flashing codes and beeping codes to help you:
In your case are any lights flashing? For example:
  • Red Power LED flashes two times, once every second, followed by a two second pause.
  • Beeps 2 times and repeats stopping after the fifth iteration but LEDs continue until problem is solved.
Possible Causes:
Processor thermal protection activated:
  • A fan may be blocked by dust (very common cause) or not spinning.
  • The heatsink/fan assembly is not properly attached to the processor.
Things to do:
1. Ensure that the computer air vents are not blocked and the processor cooling fan is spinning.
2. Open hood, press power button, and see if the processor fan spins. If the processor fan is not spinning, make sure the fan's cable is plugged onto the system board header.
3. If fan is plugged in, but is not spinning, then replace fan.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Đã bao lâu rồi bạn ko vệ sinh máy, trường hợp này trước tiên bạn hãy tháo ram ra và làm sạch, và có thể phải pin cmos nếu đã nhiều năm rồi bạn chưa thay. Thân
TRanslation Vietnamese - English
How long has it been since you cleaned your computer? In this case, first remove the RAM and clean it, and maybe the cmos battery if you haven't changed it for many years. Best regards.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
chuks williams 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 26
