주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why monitor screen upside down?
How to fix my TV monitor screen upside down?
Model Code: UA32N4000ARSER
Version No: CA02
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
My tv picture is down passion
의 공유
আমার স্যামসাং মনিটরটি 180 ডিগ্রি ঘুরে আছে
의 공유
@toqiullah if your TV is the same model you need to try the steps listed in the answer.
@toqiullah আপনার টিভি যদি একই মডেলের হয়, তবে উত্তরে দেওয়া ধাপগুলো অনুসরণ করে দেখতে পারেন।
의 공유
댓글 달기
답변 1개
가장 유용한 답변
@christophe25821 try to access the service mode for your TV. On your remote hit
POWER OFF==> MUTE==> 1==> 8==> 2==> POWER ON
if that does not work try
POWER OFF==>INFO==> MENU==> MUTE--> POWER ON
Then under the Options Menu you may have something like MRT Options, select that. There you should find something like HV flip. Give that a try. Some menu options are different due to different firmware version etc. If you can't immediately find it, keep looking for it but do not change any other items.
If your can't fix it with the Service mode then the issue could be a bad EEPROM on your mainboard. Sometimes a reprogramming of that will fix the inverted screen issue. This will require the exact firmware for your TV model, which is sometimes hard to find. In those case either a new EEPROM or a new main board should fix it
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
christopher gomes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 59
전체 시간: 457
