주요 콘텐츠로 건너뛰기
How do I get past a password on my computer
I can't get past a password on my computer. i tried to go into bios to do it but it wants an administrative password to do anything on it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I had this issue on an old laptop once, and I somehow managed to get past it by unplugging and replugging the hard drive, but it only worked once. This may work, otherwise you could try a recovery tool (I Forgot My Password, etc). Otherwise, you can try professional data recovery, but if you don’t need the data, then you can replace the hardrive or format it. Windows formatting:
Right-click the drive and select "Format."
Follow the prompts to reformat the drive
If you need the data, it will be hard if not impossible to get past the password. You may be able to plug it into a different device, which may prompt the hard drive encryption to bypass the password using the previously cached information.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Karren E Saylor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 10
