주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ford에서 제조한 콤팩트 픽업트럭, 3세대 Ranger를 위한 수리 안내서 및 지원 정보.
How to fix doors ajar
My interior light stays on all the time but my door ajar light is on dash how can I fix
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Sounds like one of the door switches has gone bad. Have you checked them? If you want specific information we'll need to know more about your rig; year and particular model would be a good start.
의
2011 ford ranger 5 speed manual transmission and manual door locks. The dome light stays on always and the doors ajar lights on the dash
의
댓글 달기
답변 1개
가장 유용한 답변
Hi @kfs99301
One of the door switches, located in the door lock has gone faulty and is permanently operated i.e. short circuit, even though the door is closed.
You will have to remove and check each door lock to find out which one. You could try spraying some WD-40 into the door lock and see if that resolves the problem.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kfs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 17
전체 시간: 276
