주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2024년 10월에 출시된 Apple의 인기 소형 폼 팩터 데스크탑 PC인 Mac mini의 세 번째 주요 재설계에 대한 수리 안내서, 분해 및 문제해결 정보입니다. M4 및 M4 Pro SoC와 최소 16GB의 통합 메모리가 특징입니다.
How could I extend the power button cable?
I am working on an application that would involve me needing to extend the power button as the Mac Mini would be unreachable. Can you help me identify the power button clip and a potential way to extend the cable further?
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Has anyone found what connector is used? If we knew what connector was used (and could get a couple) It would be easy to wire an extension and move the power button wherever.
의
댓글 달기
답변 2개
가장 유용한 답변
Depending on what your application is, I’m assuming it’s to restart as the process hung. If that’s the case then just leverage the AC power cord by placing a line switch within its path, as an example a power strip. If the application is just doing a presentation type of loop that would work. You could also setup a watchdog process from another system to manage the power strip if it has a remote control option.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
@matthewtietje if by power button clip you are referring to the connector, we don't have that information just yet. Just like all of those connectors you can most likely remove it from the actual cable. We would need to see a close up of that connector to determine how to take it off. After that its straightforward, just extend the wires but either or using a cable connector to connect a longer cable (however long you need). Then connect a SPST normally open pushbutton switch to the terminals of the extension.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks. You can see the cable being unclipped in the teardown. Hopefully someone will identify it in the near future!!
의
댓글 달기
답변을 추가하세요
matthewtietje 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 25
전체 시간: 817
