주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
클래식 Xbox 무선 컨트롤러의 세 번째 개정판은 2020년 11월에 출시되었으며, Xbox Series X 및 Series S와 함께 제공되었습니다. 이 컨트롤러는 이전 Xbox One 게임기와 PC에서 하위 호환됩니다.
Stick drift after replacing joystick module
I have replaced the right joystick module of an Xbox series controller as it had stick drift, but after replacing it the stick drift remains.
When replacing it I did notice some damage to the board so I’m now wondering if this is the cause, I’ve attached a photo so hopefully someone can let me know if that is likely the cause and if there’s anything that can be done.
Thanks, Luke
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Hi Luke!
It look like that some traces are damaged.. this need to be recovered first. Did you already tried to clean it with alcohol? If it remains, then you do need to repair the traces and try again after!
If it’s still having drift after repairing the traces, then replace it again.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hi Again! Thanks for getting back to me!
I have tried cleaning it with alcohol already and no luck. Fixing trace damage sounds like quite the ordeal, is it difficult? I’m quite new to soldering but happy to give it a try 😀
의
Hi! No problem!
Yes, it’s somewhat difficult. You need to scratch the trace with something sharp (or sand it) carefully, until you see the copper! Do this for both sides. Then solder a wire between it. So that a signal can come through again.
의
댓글 달기
Maybe try adding a little bit more solder to those pins. Especially those bottom ones. Not to much tho just a tad
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
LukeResells 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 64
전체 시간: 1,320
