주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 9월에 발표되었으며, J8210, J8270, J9210, J9260으로 알려져 있습니다.
Mobile is not working
My mobile is not turning on and not charging and also pink line issue
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@abdulahadq78484 if it is not turning on how do you know it has a pink line issue? That line issue will most likely require you to replace the screen.
As for the rest, first you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this makes a difference, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Abdul Ahad Qureshi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 14
전체 시간: 215
