주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018-2024년형 Toyota Camry는 글로벌 Camry 모델의 8세대이자 XV70으로 알려진 모델로, 2017년 1월 북미 국제 오토쇼에서 처음 공개되었습니다.
Backup camera not working
I have a 2019 Camry; a few years after purchasing, the backup camera would occasionally cut to black while functioning, or simply show a black screen, while other times it worked fine. There was no debris on the lens and I saw no visible damage to the back of the camera or any of the easily accessible wires.
Since then, it cut out for good and has not resumed; every time I reverse, it's a black screen. Something must be working, because I do get the proximity "beeps" when someone is behind me.
Asked the repair shop and was quoted $1,500 - any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
I have some problem did you find any solution?
The electric shop asked me to get a new camera
의 공유
Change the camera. Waterproofing in cameras Toyota very bad.
의 공유
wth was the resolution?
의 공유
Did you fix it ? I have the same problem, the fuses seems to be ok. It stopped working spooradically. Now it's toitally blank, I had some horizontal lines for maybe 15 secs befores it died. Looked like an old tv not tuned correctly to a channel;
의 공유
댓글 달기
답변 2개
선택된 해법
Hi @syracuse26
Have you checked that the #16 15A TV fuse in the passenger compartment fuse block is OK? Also are the reversing lights working OK?
UPDATE 12.2.2024
Hi @syracuse26
Here's the wiring diagram for the rear view camera system that may help.
It looks like there are two type of TV systems available unless one is just an enhancement on the other.
There's one known as a rear view monitor system (*6) and the other is a panoramic view monitor system (*5 & *8)
I've highlighted in a purple box the wiring paths to follow depending on which system is in use in your vehicle i.e. *6 or *5 &*8
There are 4 pages in the image.
Starting from the left the first page is just the power supply to the radio/navigation unit which seems to be working OK as far as receiving power so as to operate other reversing functions e.g. lights and proximity system etc.
The 2nd page is the circuit from the radio/nav unit to the cameras, either the rear view monitor on p.3 (*6) and/or the panoramic view monitor on p.4 (*5 & *8)
Perhaps check if there is power getting to the camera(s?) on the CB+ lead when measured to an earth (chassis), when reverse gear is selected.
If there is power at the camera then the problem could still be that the camera, the wiring (video wiring) or the radio/nav unit (as far as the rear camera circuit is concerned) is faulty but at least you know that the camera is getting power. Little steps I know but you've got to start somewhere.
Hopefully this is of some help.
이미지
Click on the image and when it opens click on it again to further enlarge for better viewing.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Hello - I just swapped out the TV fuse as suggested (it was in the engine compartment fuse box); no joy. Yes, reverse lights and all other electronics are functioning - nothing else is out.
의 공유
댓글 달기
Change the camera. Waterproofing in this cameras very bad.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My reverse camera, in my Toyota Camry 2018 XLE V6 just black out in the display with RCD off message on my screen. I checked my fuses and reverse lights, they are working fine. So I decided to replace the camera with OEM from eBay (matching the bar code in the old camera (86790-06090). It worked and the display is back, BUT the reverse camera is so zoomed in that I can only see the floor with very little back view. I also have the message RCD off, visit your dealer !
Anyone knows what is happening, may be with this camera that I bought ???
의 공유
댓글 달기
답변을 추가하세요
Syracuse26 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 51
지난 30일: 182
전체 시간: 6,254
