주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy x360은 2014년부터 HP에서 제조한 노트북 제품군입니다. 터치스크린과 완전히 회전하는 디스플레이를 특징으로 합니다.
Screen and Hinge Repair
Hello, I have a HP Envy x360 Convertible 13-ay0xxx laptop and my right hinge broke and cracked my laptop’s screen too while closing/opening the laptop.
Product Number: 9VT59UA#ABL
I need help to find the correct parts to buy (shipping to Canada) and I am unsure if simply buying a screen replacement will do the job to adjust hinge correctly.
Will it be possible to have a repair guide to replace broken hinge/screen please?
I was also looking to possibly replace the battery for a new one.
Let me know if you need more information.
Thank you in advance for your time and help!
P.S. Here is a video showcasing the issue on my laptop: https://www.dropbox.com/scl/fi/5epcs2fx2...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 1개
선택된 해법
I have reviewed your video.
You should know: your hinge is not broken, your LCD back panel is what broke. If you replace the hinges, you're not going to solve the problem and instantly this will happen again.
I do not know about vendors in and/or shipping to Canada, so I can't help you there. But you likely need the following part numbers:
LCD Cover: L94498-001
LCD Screen: L23211-001
These are the part numbers as seen from my supplier. Please note that I HIGHLY RECOMMEND you take apart your screen and find the part numbers (should be the same format as my examples, but possibly different numbers) on your exact computer before ordering replacements, as it is possible the Canada market has different parts than the US market.
Hope this helps!
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Thank you for your help!
의 공유
Yo sir I've got a same laptop and for me the top panel came off at the right hinge. Here's the link of photos https://www.dropbox.com/scl/fi/nc1glaksp...
https://www.dropbox.com/scl/fi/uvbs4kq8b...
의 공유
thats the same issue i have Bharath Reddy how do i fix it any one know
의 공유
댓글 달기
답변을 추가하세요
Leo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 10
지난 7일: 44
지난 30일: 190
전체 시간: 4,756
