Monitor no longer powers on
The monitor no longer powers on, and does not connect or power my MBP. It sounds like this is a common issue. Has anyone else solved?
좋은 질문입니까?
좋은 질문입니까?
I couldn't find the exact monitor that you have but from searching maybe this could help:
이 답변이 도움이 되었나요?
@harrisehsan don't replace anything yet until you have at least had a chance to take a look at it. Use this guide LG UltraFine 5K 분해도 to get to the boards. Then post some well-focused pictures of everything with your Question. That way we can see what you see and hopefully assist you further. Adding images to an existing question - iFixit Repair Guide
I expect this to be an issue with the power supply.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 5
지난 30일: 21
전체 시간: 422
@harrisehsan does the power LED still come on? What have you checked? What is the exact model number for your monitor?
oldturkey03 의
@oldturkey03 No it does not. Nothing happens at all. There is no real sign it is working. But I spoke to a repair shop that said the motherboard has known issues that cause this, so it should be repairable. Model number is 27MD5KA
Harris Ehsan 의
Replace the motherboard then
Senopati B. 의
@senopatib I'm hoping someone here can explain how
Harris Ehsan 의
