주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 9일에 발표된 이 기기는 Apple의 첫 번째 스마트 착용 기기입니다. iFixit의 수리 설명서는 Apple Watch (스틸) 및 Apple Watch Sport (알루미늄)에 적용됩니다.
Apple Logo Appears Only Once When Plugged In
Hello everyone!
First of all, I do not know which version of Apple Watch this is. Someone gave it to me, but did not tell me which model it is. I believe it is an Apple Watch SE, but I am honestly not sure.
Well, the Watch simply does not turn on. When I connect it to the MagSafe Charger, I see the Apple Logo for about half a second, and then it disappears. If I play with the buttons a little bit, sometimes I can get it to turn back on... but the Watch itself I cannot get to boot. I would think this is either and issue with the battery or the button itself. Since I have little to no experience with the Apple Watch, I figured I would like to hear from you guys before I get inside. What do you guys think this issue is?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 5개:
Hi @jadonlyon
Check on the back of the watch as all the information regarding model etc should be printed on there
42mm case • 7000 series aluminum • ion-x glass • composite back • serial fh7r6blzg9j
@jayeff - I am not sure if this helps
@jadonlyon
7000 series indicates that it is the original Apple watch i.e. the very 1st one released. Not to be confused with an Apple Series 1 watch which came next.
ifixit still has some parts for it but not many.
@jayeff - Oh, that's old....
댓글 달기
답변 2개
@jadonlyon
Yeah.
Given its age most likely it is a battery problem if it has never been replaced and if it hasn't been charged for a long while.
Update (12/21/24)
@jadonlyon
I've changed the device you selected for your question to the correct one for the model.
Click on the Apple watch - original icon (to the right of your question) to see the ifixit repair guide.
Cheers
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@jayeff - Then I will check that first. Thank you!
@jayeff - Thank you so much!
댓글 달기
Here’s the guide to replace the battery Apple Watch 배터리 교체 iFixit still has replacement batteries for this series. Make sure you get the kit as you do need a few other parts s well.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@danj - Thanks for this info
댓글 달기
답변을 추가하세요
Jadon Lyon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 357
