How to remove and replace the keyboard
How do I remove and replace the keyboard on a ThinkBook 16 Gen 6
좋은 질문입니까?
좋은 질문입니까?
The keyboard is part of the upper case assembly.
To remove this the laptop will have to be almost completely disassembled.
Here's the hardware maintenance manual for the laptop. Go to p.55 (61 of 74 pdf) to view the procedure to remove the upper case assembly.
Here are the parts lists for a Thinkbook 16 Gen.6 Type 21KK¹ and a Type 21KH¹ laptop that will help.
The keyboards are country specific and it also depends on the colour and whether or not it has backlighting to match the original in the laptop
Click on the appropriate type linked above and then click on Select Commodity > C-Cover with keyboard to find the part numbers for all the upper case assemblies that are used with each laptop. The country, colour and backlight feature (if available) is also shown. Scroll through the list and find the one appropriate to your situation and note the part number.
Search online for the part number only to find suppliers that suit you best. The part number is located somewhere on the underside of the upper case assembly if you wish to verify before ordering.
¹The Type number (Machine Type or MT) can be found on the product information label on the bottom of the laptop
이 답변이 도움이 되었나요?
Thank you for this. I found the hardware maintenance manual really helpful in having the confidence in what I was doing (which was ensuring the trackpad cable was well connected) - unfortunately, the trackpad is still not visible, so I guess I need a new one.
Hi @mikeclargo
Have you tried pressing the Fn + m keys (both together) just in case the trackpad has been disabled?
Also check in Device Manager → Mice and other pointing devices (or HID (human Interface Devices) to see if the trackpad is shown there and is OK
Dear @jayeff - yes, I have exhausted all of the keyboard, software, driver options - which is why I am now onto hardware (which is why I am now iFixit empowered) so I have checked the trackpad cable, and there frankly is only one thing left. I did just try Fn + m because I felt at this point it would be wonderfully ironic if it worked. But it didn't.
지난 24시간: 7
지난 7일: 27
지난 30일: 96
전체 시간: 1,274
