주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi 기능이 포함된 충전식 열화상 카메라
Replacement LCD Options For Klein TI270 Infrared Camera
Needs some suggestions for finding a replacement LCD. It's a 45pin 3.5" 320x480 TFT LCD. Can't seem to find anything remotely close and customer service wants nothing to do with it. Seem like a waste for a $400 camera since it's just a simple LCD. Looks like the unit runs off a ARM STM32h750.
이미지
이미지
이미지
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @aaronmcmahon,
Can't find replacements by searching for the part number shown on the back of the display.
Without knowing the make and model number of the screen so as to hopefully find its datasheet to get the flex cable pinout and voltage requirements for the screen info etc finding a compatible screen will be difficult if not impossible.
Have you tried checking if it is a backlight problem, that may be related to the motherboard and not the display?
Turn on the camera and then try shining a flashlight at an angle close to the screen and check if you can see any images at all.
They will be very faint if they are there, so trying this in a darkened room may help .
if there are images to be seen, then it is a backlight problem.
Next you have to determine if it is in the display or on the board.
Looking at a close up image of the screen connector (see below) there are two things I check.
a). Check if the diode marked D1 is OK
b). Check if there's battery and ground on the motherboard connector pins that line up with the two highlighted wires, (see image) where the flex cable plugs in. Check with the flex cable removed. Be careful that you don't short them out when using the test probes of your DMM (digital multimeter) as they're very close to each other.
It may be that the motherboard circuit design requires that the screen be plugged in so as to apply power to the backlights. I don't know, it's just what I'd try.
If there is power on the relevant connector pins, then the problem is in the screen.
If there's no power on the connector pins then post an image of the motherboard (both sides).
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 11개:
I wish it were that easy :( Screen is cracked.... I should have been more specific. Works but most of it you can't see
I've tried searching for the any info on the screen online but can't find anything. I did buy some breakout boards to try adapting a 40 pin screen but seems really tricky. Im pretty sure the pins 41-45 are unused (45 is a ground) so might be possible.
I know nothing about LCDs so this is a first for me. I've seen a lot of talk about Driver ICs but from what I can find on the PCB there isn't one so the ARM might handle that??
Thank you for commenting! I was beginning to lose hope anyone would chime in.
@aaronmcmahon
If the screen is cracked you may have nothing to lose by trying to remove the back from the screen and check if there's any circuitry in the screen itself.
Lots of bigger displays have onboard driver ICs
Ahhh ok good call. Its cracked beyond and usability. I will have to see if it's hiding any secrets
@aaronmcmahon
This may be of interest to you.
Thats great! Seems I will need to figure out what mode it uses. Luckily it's not touch so I don't need to worry about that
댓글 6개 더보기
댓글 달기
답변을 추가하세요
Aaron McMahon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 27
전체 시간: 362
