주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 출시. Lenovo에서 제작한 Android 태블릿으로, 멀티미디어 콘텐츠를 투사할 수 있는 내장형 비디오 프로젝터가 포함되어 있습니다.
Damaged something during battery replacement.
I accidentally damaged the adhesive beneath the battery and more, because I had to use tweezers to loosen the battery some more after removing the adhesive pull tabs.
Is it still save to install a new battery?
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi @nutzer39892
It looks like you damaged the double sided adhesive strips that are used to help secure the battery to the case.
You can install the battery but ensure that it is secured to the case using suitably thin and sized double sided adhesive tape strips. You don't want the battery moving around inside the case.
Here's information if you wish to get the tape strips used in the tablet. Make sure that you remove the old strips first before installing the new ones..
Search online for SD78C03373 to find suppliers that suit you best.
Here's an image showing what it looks like.
Note. The same tape is used in a lot of Lenovo tablets so ignore the results as showing for a particular model. The part number for the tape is in the parts list for your model as well. Click on Select Commodity > Die Cut pieces\Double-sided Adhesive and Foam (4) and view the part number shown for the Blade3-10 DLP-Tape Tape 20 part
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks very much!
의
댓글 달기
답변을 추가하세요
Professional 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 24
전체 시간: 240
