Gameboy advance SP Red Screen Tint
Hi, I bought this GBA SP 101 on ebay and it has this red filter on the screen and is mainly noticable on black screens. Is this caused by the ribbon cable or the polarizing film? Or something else?
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
Hi!
Could be both actually. Only thing to do is to disassemble it and check the ribbon cable and screen. Unfortunately, you probably need to replace the screen (cable is fused) to fix this.. Sorry!
이 답변이 도움이 되었나요?
Here are some causes and potential solutions if your Game Boy Advance SP (GBA SP) screen appears red.
Possible Causes:
Inspect the Battery: Display distortions (including color tints) can occur if the battery is low or failing.
LCD Damage — A defect or degradation in the screen itself.
Screen ribbon cable problem; A loose or faulty ribbon cable is responsible for causing color distortion by connecting the screen to the motherboard.
Backlight Type: If you own a front-lit (AGS-001) model, the lit screen can on occasion
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 1
지난 30일: 27
전체 시간: 45
