주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
게이밍 PC는 비디오 게임 플레이에 특화되어 최적화된 개인용 컴퓨터입니다.
PC will not boot up
I hit the power button, fans turn a few times but won't start up. Sometimes the RGB lights turn on but nothing else.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi @zombieslay72601
What is the make and model number of the PC or motherboard if it is a custom build?
의 공유
댓글 달기
답변 3개
It’s sounding like your PC is having a power issue. Here are a few troubleshooting steps to attempt:
Check the Power Supply (PSU)
Make sure that the power cable plugged into the wall outlet and into the PSU is firmly in place.
Use an alternate power cable or wall outlet.
If you have a PSU switch (I/O) turn it off and on.
If possible test with another PSU.
Check for a Short Circuit
Turn off and disconnect everything.
Open your case
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well you can try the following:
  1. Try a different power source.
  2. Check your monitor connection.
  3. Disconnect your devices.
  4. Listen for beeps if any coming.
  5. Start your PC in safe mode.
  6. Restore your computer to previous settings. .
  7. Check for unresponsive apps.
  8. Unplug USB devices.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Your PC may have a power supply, motherboard, or RAM issue. Try these steps:
  1. Check power cables and connections.
  2. Test with a different power outlet.
  3. Reseat RAM and GPU.
  4. Clear CMOS by removing the battery.
  5. Test with another PSU if possible.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Zombie Slayer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 16
전체 시간: 435
