주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung은 2024년 1월 17일 “Unpacked/언팩” 행사에서 Galaxy S24 라인을 발표했습니다. 삼성 갤럭시 S24는 2024년 주력 스마트폰의 기본 모델입니다.
Screen + frame replacement Samsung S24
Hello!
I replaced the [screen+frame] unit on my S24, and the buttons ont the side of the phone don't work anymore. The screen works when I put the phone on charge but I only have a logo with the circle and the little lightning for a few seconds.
Can anyone help me to fix this please?
Thanks a lot :)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Is the phone charging? I know you see the lighting logo but, does the green circle increase? If so, we know the phone is atleast taking a charge.
The S24 replacement part with frame usually has the power button and volume button built into, so you dont have to transfer them. I would check to make sure though. Usually, you can tell if the buttons click properly or not.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for your answer! No, the green circle doesn't increase. I had to transfer the buttons but I did it well and easily. The buttons click properly.
의
You're welcome. I would double check all the connections such as the battery and charge port. The fact that the battery isnt charging leads me to believe the charge port isnt being seen by the mainboard. Once the phone is taking a proper charge and you see progress on the screen that the phone is charging, I would test the power button again.
의
댓글 달기
답변을 추가하세요
Haha Hihi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 24
전체 시간: 560
