주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 k52t38(Lenovo Vibe K5 Note로도 알려짐)—2016년에 처음 출시된 5.5인치 디스플레이 탑재 안드로이드 스마트폰입니다. 샴페인 골드 및 플래티넘 실버 색상으로 출시되었습니다.
phone switch off not starting
not able to start the phone when connecting to charger only red light comes but does not starts
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If you see a red light when connecting your phone to the charger but it doesn’t start up, it suggests that the phone is receiving power, but it might not be able to boot up properly.
If the phone has a hardware issue with the battery or the internal power supply, it could cause the phone to not start even when charging. The red light may be an indicator of this issue.
In this case, charge for at least 30 minutes to an hour before attempting to power it on. Sometimes, if the battery is deeply drained, it might take a while for the phone to show any signs of life. Ensure you're using a reliable charger.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
i charged the phone and also i removed the battery and added new battery to it but than also not starting what will be the issue in hardware i am technical guy would you recommend me the schedule
additionally i remove the battery and i connect the charger without battery also than also red light was coming but the phone was not starting
@rahulyadav37502 If the light stays on even with the battery in and no boot, the issue might not be the battery itself. A failed motherboard, damaged power button, or blown fuse (common in older phones after battery issues) could be at play.
댓글 달기
답변을 추가하세요
Rahul Yadav 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 30
전체 시간: 264
