주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IdeaPad 110-15ACL은 1 TB 하드 드라이브와 8 GB의 메모리를 탑재한 15.6인치 노트북입니다. 이 노트북은 보급형 사무용 노트북으로 설계되었습니다.
My computer won't boot. Surcure Boot won't load.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Hi @wilkil
Won't boot or won't start, there is a difference.
Either way try a full power refresh and check if that resolves the problem.
  • Disconnect the charger from the laptop if connected.
  • Open the laptop and disconnect the battery from the systemboard.
  • Disconnect the RTC (aka cmos)coin cell battery from the motherboard. Unfortunately for you, the RTC coin cell battery is on the underside of the systemboard so it will have to be removed to get to it. Go to p.46 (50 of 82 pdf) of the manual linked in the answer above to view the procedure to remove the systemboard from the laptop. (see image below for location of RTC battery)
When the RTC coin cell battery has been removed, measure its voltage. If it is <2.5V DC or if the battery is >4-5 years old, replace it. Search online for Lenovo IdeaPad 110-15ACL CMOS Bios Battery to find battery suppliers that suit you best. (examples only)
  • Reconnect the RTC coin cell battery to the systemboard
  • Reinstall the systemboard into the laptop (reverse the removal procedure), reconnect the battery, close the laptop and connect the charger and check if it turns on OK.
If the laptop turns on OK, there might be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset back to default by the above procedure. Once the date and time have been corrected, the message won't appear the next time the laptop is started. Also if any user definable BIOS settings were changed by you to suit whatever system requirements were needed, they will need to be changed back again as well.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
@wilkil you may have to reinstall your OS. I would start off by trying to set the BIOS to boot from USB drive and then use a bootable USB drive. See if that gets' your computer to boot. You may then access the current data drive and see what issues it may have, and possible restore your OS.
To work on your computer and how to set it up, use the Lenovo IdeaPad 110 15ACL Hardware Maintenance Manual
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My laptop is start and loading many times
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well I will suggest you to checkout the following video: https://www.youtube.com/watch?v=I65j7U6m...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Wil Kil 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 30
전체 시간: 238
