주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 3월에 출시된 삼성의 열 번째 갤럭시 플래그십 스마트폰입니다. Android 9.0(Pie)이 탑재되었습니다.
My finger print sensor not working
My fingerprint sensor not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개:
Not working for my mobile sensior fingerprint working mobile sumsing s10
의
@noorullahmehsud you have followed all the suggestions given in the original answer? You have replaced the sensor?
의
댓글 달기
답변 3개
@samwelmhilu you are not giving us much to work with here. It would be great if you could tell us what it is doing, what you have checked and what you have tried.
First check the basics. for that use the suggestions from this Samsung site. After that you need to dig a bit deeper. Try to do the hardware diagnostics by going to dial and enter *#0*#, then select Sensors and sub options in Fingerprint Scanner. See what that shows you.
Should that not work either you can try to do a "wipe cache" after booting into recovery mode. The last option would be to do a hard reset, just remember that with that, you will lose all of your files that are stored on your phone. Make sure that you back everything up first before contemplating a hard reset.
If none of that works or the sensor is not responsive, you may need to consider replacing it.The S10 fingerprint scanner is located on the front of the screen. Check this video Samsung Galaxy S10+ 분해도 at around the 2min mark. It is the same location as the S10
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My fingerprint sensor is not working.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Fingerprint is not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Samwel Mhilu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 40
전체 시간: 765
