screen filled with lines
좋은 질문입니까?
@mickey53796 you're not giving us a lot to work with here. It will help if you post some pictures of what your screen actually shows. 기존 질문에 이미지 추가하기
Connect an external monitor to your Lenovo and see if that shows a clear picture. If so, then the issue is most likely a bad LCD screen on your computer. If an external monitor shows the same lines then the issue is with your GPU on your motherboard.
Use this Lenovo Ideapad 110 14 15 Series Hardware Maintenance Manual to work on your computer (if you do need to change the LCD assembly etc.)
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 241
