주요 콘텐츠로 건너뛰기
The rotating side brush is no longer rotating
I've unscrewed the screw that holds the brush in place, removed the brush, cleaned the area, and reinstalled the brush without success.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
As it appears that you've already taken a few easy steps without success, there is most likely something wrong with the side brush motor assembly.
Luckily an awesome Ifixit contributor has created a guide on replacing it!
it can be found here:iRobot Roomba 630 Side Brush Motor Replacement
while the model number is different it shares the same construction and should still work.
Hope this is helpful!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks! I've ordered a replacement motor. Hopefully that will do it.
댓글 달기
답변을 추가하세요
Carorhoomba 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 32
전체 시간: 32
