주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 3월에 출시된 삼성의 열 번째 갤럭시 플래그십 스마트폰입니다. Android 9.0(Pie)이 탑재되었습니다.
Low temperature battery issue
I recently been getting this issue, Pressing on the back where the wireless contacts connect usually fixes it, Now it just won't charge at all, Any good places to find a replacement wireless charging pad for it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@chriscodm you are not telling us if it still charges by wire. I would suggest a new battery as well. Wireless Charging Module is available at many places including on here
Update (03/26/25)
@chriscodm If a new battery and the charging module do not yield any results, follow the Samsung troubleshooting flowchart for the not charging (both wired and wireless)
이미지
이미지
Use the Samsung Galaxy S10 Component Layout and your PDF readers search function to locate the component to check (i.e. C8144) on your main circuit board. Measure the values listed and replace/repair as needed. This is for the charging only. If you look at the flowchart you see that they have one IC in common and that is U8031. Samsung part number for that is 1203-009156 and it is referred to as the Power Supervisor IC the actual IC is a MAX77705C and it is readily available at many online places. Probe around that one.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It doesn't charge in either way, both wired and wireless, but thanks for finding a replacement part!
의 공유
댓글 달기
답변을 추가하세요
ChrisCodm 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 24
전체 시간: 419
