주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Volkswagen Group B5 플랫폼을 기반으로 한 완전히 새로운 Passat가 1998년 북미에서 출시되었습니다.
Charging problems with battery
My battery won't charge
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@shirleylar63859 let's start off by clarifying what you have checked. Have you checked your battery? Have you checked your alternator? Use a voltmeter and measure the battery voltage between the positive and negative post. It should be around 12V Next, with your Passat running measure the voltage between the positive and negative post. What voltage do you get (expected is around 13.5V to 14V DC). If you have that voltage, it is most likely your battery. If you do not have that voltage, it could be your alternator. Let us know what you find out.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
well, you must start by doing something and letting us know what you did.
Your question is like my car won't run. What's wrong?
Start by taking it to AutoZone or Advance Auto, They can check the battery and alternator.
That alone will likely get you an answer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shirley Larson (Squirrel) 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 165
