주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
공식적으로 Chevrolet C/K라고 불리는 C/K는 General Motors에서 제조하고 Chevrolet 및 GMC 브랜드로 판매된 트럭 시리즈입니다. C/K 라인업에는 픽업트럭, 중형 트럭 및 대형 트럭이 포함됩니다.
Exhaust backfire and Missfire
98 c1500 5.0L. I have a backfire it sounds like my exhaust is kicking into my floorpan. It only happens after the vehicle hits operating temperature. I have replaced the Spider Fuel injectors, wires, plugs, and distributor.
It just started throwing a P1345 code. But has had a misfire code for a random misfire
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@dakotasanders based on the symptoms you are describing as well as the P1345 code, this sounds like either a bad camshaft sensor or a bad timing settings. Since P1345 relates to the camshaft and crankshaft sensors alignment to each other, you can't count out the crankshaft sensor either. I'd replace the sensors, reset the PCM. This from a workshop manual
DTC P1345 - CRANKSHAFT/CAMSHAFT POSITION SENSOR CORRELATION
Circuit Description
DTC determines if distributor is installed incorrectly, or if a mechanical malfunction is present in engine.
DTC will set when engine is running, cam sensor reference pulse is not detected at correct relative position with crank pulse.
Diagnostic Procedures
1. Perform POWERTRAIN ON-BOARD DIAGNOSTIC (OBD) SYSTEM CHECK , then go to next step.
2. Install scan tool. Start engine. Using scan tool, monitor engine RPM. If engine RPM fluctuates up to twice the expected RPM, go to next step. If engine RPM does not fluctuate up to twice the expected RPM, go to step 4).
3. Replace crankshaft position sensor. After replacing sensor, go to step 8).
4. Check for proper installation of distributor. If a problem is found, go to step 7). If no problem is found, go to next step.
5. Check for proper installation of distributor. If a problem is found, go to next step. If no problem is found, go to step 8).
6. Repair as necessary. After repairs, go to next step.
7. Replace distributor. After replacing distributor, go to next step.
8. Using scan tool, select DTC, CLEAR INFO. Start and warm engine to normal operating temperature.
Select DTC, SPECIFIC, then enter this DTC. Operate vehicle within the conditions for setting this DTC.
If scan tool indicates that this test ran and passed, go to next step. If scan tool does not indicate that this test ran and passed, repeat step 2).
9. Using scan tool, select CAPTURE INFO, REVIEW INFO. If any undiagnosed DTCs are displayed, go to applicable DTC test.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Dakota Sanders 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 140
