주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
비즈니스용으로 설계된 합리적인 가격의 HP 노트북입니다. 2022년 5월에 출시되었습니다.
Battery drains very quickly
May I ask, I have a laptop with this model and it is more than 3 years old. I have a problem with my battery. Recently my battery runs out quickly even though it has been fully charged. Now it only takes a few minutes to use. Is this problem called battery leakage or not. If so, then I ask for a solution
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @aydemaram
Create a battery report to check the condition of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value as shown by the report. For a good battery they should nearly be the same value.
You can work out the condition of the battery as a percentage by using the formula Full Charge Capacity value x 100 ÷ Design Capacity value. If it is <35% consider replacing the battery.
If the battery needs replacing, here's the maintenance and service guide for the laptop that will help. Go to p.29 (37 of 88 pdf) to view the procedure to remove/replace the battery.
At the top of p.29 you will find the HP part numbers for the 2 battery models that can be used. Usually the part number is found on the battery somewhere if you wish to confirm which one you have now. Search online for the applicable part number only, to find battery suppliers that suit you best.
Once you have replaced the battery, remember to dispose of the old battery responsibly. The environment will thank you for doing this.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Aydem Aram 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 25
전체 시간: 203
