주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Craftsman Riding Mower 917.271551은 15.5마력 엔진으로 작동하는 승용 잔디깎이입니다. 이 페이지에서는 연료 용량이 1.25갤런이고, 다양한 지상 속도와 3 암페어 충전 시스템, 28 Ah 배터리 등의 사양을 갖춘 이 모델에 대한 수리 및 기타 정보를 제공합니다.
Where is the fuse?
The manual says the fuse is behind the dash but I can't find it, and does not show where it is. After we disengaged/reengaged, the tractor no longer works (we needed to move the tractor manually out of a small ditch). When turning the ignition, we do not hear a clicking sound. Replacing the solenoid didn't fix the issue. The battery is good. We haven't yet checked the fuse because we can't find it. Would appreciate any help. Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @pclee001
Do the headlights work OK when you turn the ignition switch to the lights position?
If they do then the fuse is OK.
If they don't then the fuse may have blown. It's a 20A blade type fuse part # 175158 (examples only)
On p.31-p.32¹ of the owner manual it shows the wiring diagram and the harness layout for the mower. The fuse connects between the ammeter (if installed) or the B terminal of the ignition switch and the solenoid so it may be just hanging out of the harness sleeve between the two points.
¹ For some reason p.32 is not showing in the manual when I post the manual in the answer so here's an image showing the harness layout. It's used in conjunction with the parts list shown on p.33. The fuse is part #26
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thanks, we tested the battery again, followed by the headlight. The headlight didn't turn on. We found the fuse with your image, tested the fuse which gave a 0 / near zero reading on continuity. We will purchase a spare fuse just in case, but not sure what to do next for the troubleshooting since replacing the solenoid didn't work too.
의
Thanks @jayeff, it works now. Turns out the fuse was loose.
의
댓글 달기
답변을 추가하세요
Pclee001 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 55
전체 시간: 729
