주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude E5570에 대한 수리 정보 및 문제해결 방법입니다. 이 기기는 6세대 Intel Core 프로세서를 탑재한 15.6인치 비즈니스용 노트북 컴퓨터입니다. 2016년에 출시되었습니다.
Black screen of death
So when I turn on my laptop I get greeted with a black screen, some trouble shooting I have done it trying to reinstall windows (I still saw black screen), when i press caps lock nothing happens, when I try to open bios nothing happend, i have tried reseating ram, using a differant hard drive, doing a hard reset, took out the cmos battery then put it back in, tried plugging it into moniter with hdmi and vga, nothing works,
Any help would be appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Does the screen turn on but not show anything or can you see the backlight on?
의
@uptempoguy the backlight is not on at all. the screen is copletely black, same as when its turned off
의
댓글 달기
답변 1개
@heathbrown43963 check your backlight (most likely not the issue sine you also have no pictures on an external monitor). Turn your computer on and in a darkened room, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
It is possible that this is a bad BIOS. You may need to consider reflashing it. Of course, there is also a possibility that this is a failure of your GPU circuitry on your motherboard.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Heath Browning-Davies 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 24
전체 시간: 344
