주요 콘텐츠로 건너뛰기
1.6, 1.8, 또는 2 GHz G5 프로세서
20 질문 전체 보기
blank screen and shuts down after 10 seconds
iMac G5 17 Model A1058
when pressing power button on g5 imac it makes startup noise but the screen does not do anyting and then it shuts itself down after about 10 seconds
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
선택된 해법
Open it up by removing the back. There are four diagnostic lights on the logic board. Let us know what they are telling you. Also inspect the 24 "cans" capacitors for swelling and/or corrosion.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
the capacitors by the processor have corrosion on the top...i picked this unit up knowing it was broken but am really hoping i can fix it for my little brother who loves apples (as do I). I'm pretty mechanically inclined so I'm hoping I can fix what happens to be wrong. I saw on another site ppl soildering new capacitors, is that a common problem for a unit this old? Thank for all you help.
I'd also like to edit my original post, after opening up the unit and starting it from there I notice bootup sound, and HD cranks...still no screen....lights 1 and 2 stay a constant green. Before I thoguht it cut itself back off but after leaving it to see if the lights change i notice all the fans speed up to a highspeed. Hope this helps.
Here's the most knowledgeable guy I know of on the capacitor problem: http://jimwarholic.com/category/imac_g5
댓글 달기
I have the same problem: the boot up sound and the fans and HDD working but no picture on the screen. My leds 1, 2 and 3 are green and 4 is off.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 926
