주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 처음 출시된 ILX는 미국 Honda Motor에서 제작한 소형 세단입니다. ILX는 작고 효율적이며 신뢰할 수 있을 뿐만 아니라 스포티한 자동차로 알려져 있습니다.
Calibrating Accelerator Pedal Position Sensor
I replaced the accelerator pedal and sensor on my 2013 ILX due to issues with limp mode, rough idling, rough gear changes, engine check light on, etc. It didn't solve the problem. However, it may be that I need to recalibrate. I tried all the methods I could find on the net but nothing works. Do I need to take it to the dealer to recalibrate. They are asking $500. I was hoping there is another way. I read that it can be done with an OBDII scanner. But I do not have one. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @profbijan
Since you haven't got a ODDII scanner, if the vehicle is driveable, take it to one of the major retail chain auto parts suppliers e.g. AutoZone, Pepboys, O'briens etc and ask for a free OBDII code check. Most of them will do this for free.
Check if any P2122. P2123, P2126→P2128 & P2138 are logged
Here's an image showing what each of the codes mean. Hopefully this may be of some help.
이미지
(click on image)
Update (05/16/25)
Hi @profbijan
Could only find information on P2101 code. (see below) and not on any of the others
이미지
(click on image).
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
My local mechanic says that the scanner is showing DTCs P2101 and P2179. He cleaned the throttle body and replaced the APP pedal assemble which has the sensor built in but no joy. Tried calibrating the APP using procedures on the net but didn't solve the issue. Acura DTC P2010 suggests that the PCM needs to be updated with the latest software or the PCM is faulty. Acura says there are no doftware updates. Nothing seems to work.
의 공유
댓글 달기
답변을 추가하세요
Prof Bijan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 32
전체 시간: 335
