주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dodge Avenger라는 명칭은 2007년 2월, 2008년형 세단 모델로 부활하여 Dodge Stratus를 대체했습니다. Dodge Stratus의 쿠페 버전은 2001년에 기존 Avenger를 대체했었습니다.
Catalytic Converter low threshold
이미지
I keep getting a check engine light for a catalytic converter low threshold code. I don't have the money to replace it. Is there any way to clean it and extend life?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
P0420/P0430 typically indicates that the cat isn't performing at 95% efficiency, and it usually does not affect drivability. If the honeycomb structure in the cat were broken, that could cause issues, but as long as the cat is intact, it's just running at 0-94% efficiency.
You could swap the 02 sensor that goes the cat and see if that clears it up, but I would say 8/10 times the cat is bad. Unless you live in an inspection state I would drive the car like that and not bother replacing the cats on such an old car. 11-17 years on the original cat is when you accept the code will be there for the remaining life of the vehicle, as the cost of a new cat is usually significantly more than the car is worth many years later.
FCA cars are known to experience issues with the cats as they age, so it's not uncommon for their vehicles to develop a cat problem as they age out.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
@couponlover57 not really, but make sure that this is caused by the catalytic converter. There is always a possibility that this is connected to some faulty O2 sensor, bad fuel injectors or even issues with an exhaust leak. Let us know the exact code(s) your scan showed.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Added picture
의
댓글 달기
답변을 추가하세요
couponlover57 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 420
