주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Filter is not recognized
I already changed all filters but the screen is showing that the filter is no recognize
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
가장 유용한 답변
@marlyncardona
Check that the filter cover (with the filter inserted) is fully closed when the buckles are secured to hold it in place.
It may be that there's a microswitch that is operated when the filter is in position and everything is closed indicating that everything is as it should be.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I am in the restoration industry where using this piece of equipment is common and i can confirm in order to get the unit to recognize the filter you need to ensure the internal filter clips snaps on to the grooves or it will continue to display the filter not recognize prompt and only work at a low speed
의 공유
댓글 달기
답변을 추가하세요
Marlyn Cardona 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 68
전체 시간: 1,085
