주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
iPhone X screen keeps going black
It's just that the screen is coming off, from all 4 corners. I dont know what to do if i take the screen off. What should i do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
Well I will suggest yo to watch the following video it might help you in fixing the issue with your iphone:
https://www.youtube.com/watch?v=_gW-Bo9f...
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
the screen is popping off a bit, it fell down and since then it just keeps going black. If i dont press on the screen it goes black, if i apply pressure it doesnt
This won't help with a hardware problem with the screen. All you're doing is a hard reset, which is frequently useful but not in this case.
댓글 달기
I have the same thing happening to my XR. Is the entire screen popping out or just like the front glass? Because on mine if you look from the top you can actually see the backlight of the screen as it is actually separating instead of coming off. Are you still able to sometimes use it, and does the touch work?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If the screen is coming off it's usually a swollen battery causing it. Open it up and see if it's swollen. It'll need replaced if it is.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
adra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 221
