์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
Xiaomi Poco X3 Pro๋Š” 2021๋…„ 3์›”์— ์ถœ์‹œ๋œ Xiaomi์˜ ๋ณด๊ธ‰ํ˜• ์Šค๋งˆํŠธํฐ์ž…๋‹ˆ๋‹ค. 6.67์ธ์น˜ IPS LCD ํ™”๋ฉด๊ณผ 48MP ๋ฉ”์ธ ์นด๋ฉ”๋ผ๋ฅผ ํƒ‘์žฌํ–ˆ์œผ๋ฉฐ Qualcomm Snapdragon 860์œผ๋กœ ๊ตฌ๋™๋ฉ๋‹ˆ๋‹ค.
Phone is Dead (POCO X3 Pro)
๐Œ๐ฒ ๐๐จ๐œ๐จ ๐—๐Ÿ‘ ๐๐ซ๐จ ๐ฐ๐š๐ฌ ๐ฐ๐จ๐ซ๐ค๐ข๐ง๐  ๐Ÿ๐ข๐ง๐ž. ๐Ž๐ง๐ž ๐๐š๐ฒ, ๐ˆ ๐ฉ๐ฎ๐ญ ๐ข๐ญ ๐จ๐ง ๐œ๐ก๐š๐ซ๐ ๐ข๐ง๐ , ๐›๐ฎ๐ญ ๐š๐Ÿ๐ญ๐ž๐ซ ๐ญ๐ก๐š๐ญ, ๐ข๐ญ ๐ง๐ž๐ฏ๐ž๐ซ ๐ญ๐ฎ๐ซ๐ง๐ž๐ ๐จ๐ง ๐š๐ ๐š๐ข๐ง.
I tried different chargers and pressed the power button many times, but nothing happened. The screen is completely blackโ€”no light, no vibration, no sign of life.
I took it to a few mobile repair experts. They tried to revive it by revoking the processor maybe, but it didnโ€™t work. One expert said the memory chip might be the problem and could need repair.
The most important thing is, I have very valuable data in that phoneโ€”photos, files, contacts, and work documents. I donโ€™t have any backup, and I really need this data.
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 1
๋Œ“๊ธ€ 1๊ฐœ:
เฆฏเฆ–เฆจ เฆ†เฆฎเฆฟ เฆซเง‹เฆจเฆŸเฆฟ เฆšเฆพเฆฐเงเฆœ เฆฆเฆฟเฆšเงเฆ›เฆฟเฆฒเฆพเฆฎ เฆคเฆ–เฆจ เฆซเง‹เฆจเฆŸเฆพ เฆเฆ•เฆŸเง เฆธเฆ• เฆฆเง‡เฆฏเฆผ เฆเฆฌเฆ‚ เฆซเง‹เฆจเฆŸเฆฟ เฆ“เฆฐ เฆนเฆพเฆค เฆฅเง‡เฆ•เง‡ เฆชเฆกเฆผเง‡ เฆ—เฆฟเฆฏเฆผเง‡ เฆกเง‡เฆก เฆนเฆฏเฆผเง‡ เฆฏเฆพเฆฏเฆผ
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
@albertmarshall that is the age old problem with not having backups. There is no way you get the data of your phone unless you get the phone to start up. Transplanting or replacing the memory IC will not recover your data.
You need to determine where the error is. Something like this "revoking the processor maybe" does not tell us much since we do not know what they did. Nor do we know what they have checked. Commonly a no power situation is related to either the charging board, a shorted battery or a torn flex that comes from the daughter board to the main circuit board. Check/replace those. Then check the voltage on your battery connector with the phone plugged in and without.
To replace the battery, use this guide Poco X3 Pro ๋ฐฐํ„ฐ๋ฆฌ ๊ต์ฒด For the rest use this video Let us know what you find out.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Albert Marshall ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 1
์ง€๋‚œ 7์ผ: 12
์ง€๋‚œ 30์ผ: 34
์ „์ฒด ์‹œ๊ฐ„: 637
