주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Frigidaire에서 제조한 냉장고의 수리 정보, 서비스 가이드 및 문제해결 도움말입니다.
Resetting the reset indicators
Refrigerator: Frigidaire model GRSS2652AF
Age: Just past the warranty period
Both the ‘Reset water filter’ and ‘Reset air filter’ indicators are on. The manual clearly states “15: Air Filter The display shows the current status of the air filter (Good, Order, or Replace). To reset the filter status to Good, press and hold Air Filter for 3 seconds.” I have done this, but the indicator is still lit. Exact same thing for the water filter.
What else can I try?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Replace filter,makes ice no water
의
@arthurfranklin
Try pushing the filter in a fraction more so that you hear it click.
If it won't go in any further, turn off the water and remove the new filter and reinsert the old filter (until you hear it click into place) and check if you get water.
Sometimes replacement filters if they're not OEM are not exactly the correct specifications regarding the tabs so it doesn't quite fit correctly to open the valves in the filter housing when it's inserted.
의
댓글 달기
답변 1개
가장 유용한 답변
Can't say for sure, but have you tried physically removing and replacing the filter? If it has sensors such that it can tell if it's installed then it might not allow a reset unless it thinks the filter has been replaced.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
My understanding is that the filters are simply timer based and that they do not measure anything.
의
댓글 달기
답변을 추가하세요
Gerry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 40
전체 시간: 1,336
