주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년에 출시된 Lenovo Ideapad Gaming 3 15ACH6은 Ryzen 프로세서와 NVIDIA GeForce 그래픽을 탑재한 보급형 게이밍 노트북입니다.
Something whit the screen
The whole laptopt its fine but the screen is like disconected cause dont turn on dont matter what just its off, not a poor black or grey light nop just its off
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @urielfernandez
Try connecting an external monitor (TV?) to the laptop's HDMI port and check what the display from the laptop is like when viewed on the TV. Don't forget to press the change display hotkey on the keyboard to switch the display from the laptop screen to the TV.
If there's no display seen on the TV screen then there's a motherboard problem and further testing would be required.
If the display seen on the TV is OK, switch the display output back to the laptop and then try shining a flashlight at an angle close to the laptop screen and check if you can see any images at all on the screen.
They will be very faint so trying this in a darkened room may help.
If you can see images then there's a backlight problem with the display - faulty backlight power supply, faulty LCD cable/cable connection or a faulty LCD panel.
If there are no images on the screen then there either a problem with the LCD cable/cable connection or a faulty LCD panel.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Uriel Fernández 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 191
