주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy x360은 2014년부터 HP에서 제조한 노트북 제품군입니다. 터치스크린과 완전히 회전하는 디스플레이를 특징으로 합니다.
Can we change Ram.
HP envy x360
Update (07/22/25)
이미지
Here is the image
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @amarjitsah
Wat is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
의
HP envy x360 convertible
의
댓글 달기
답변 1개
선택된 해법
Hi @amarjitsah
Your laptop is a HP Envy 13-ag0035AU
Unfortunately, the memory cannot be upgraded in the laptop.
There is 8GB of onboard memory on the motherboard which is non removable i.e. soldered onto the board and there's no extra memory slot on the board to insert any more.
You're limited to what you already have.
Here's the maintenance and service guide, taken from this support page for your exact model¹. Go to p.32 (40 of 79 pdf) to view the procedure to remove the memory shield which exposes the onboard memory, if you wish to verify.
¹ Note that the model number (HP ENVY x360 - 13-ag0035au), serial number (8CG92482W6) and product number (5FP71PA) for the laptop shown in the support page is exactly what is shown in the image that you posted.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
How to improve it's overall performance?
의
@amarjitsah
There's nothing that you can do to the hardware that will improve performance.
There's already an SSD installed for storage (they are faster than a HDD), you can't increase the memory, and you can't replace the CPU.
Make sure that the Windows OS and the hardware drivers (check in Device Manager) are up to date and that there are no viruses or malware installed which could slow things down
의
But in cmd prompt it shows that I can upgrade it upto 32 gb ram
의
@amarjitsah
Open up the laptop and you will find that there's no way to do this as you cannot remove the old ram and there's no empty ram slots to install any more.
의
댓글 달기
답변을 추가하세요
Amarjit Sah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 27
지난 30일: 82
전체 시간: 2,001
