주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2023년 9월 28일에 발표된 Raspberry Pi 5는 Raspberry Pi 4B의 하드웨어를 개선한 제품입니다.
Pi is not booting up
I connect ot to the power supply and it shows red light, (my pi camera was shorted and burnt a bit from since my pi is showing red light) it is not showing green light, fan doesn't spin and a minor current i feel when i turn it on any fix?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
troubleshooting steps:
  • See if a pc can recognize the device.
  • Reprogram the firmware
  • Check if the SD card is working properly
  • Check the voltage rails on the GIPO header pinout is found here
이미지
how to change boot mode and other pi hardware documentation is found here
이 답변이 도움이 되었나요?
점수 0
댓글 달기
@prasadgawas since this happened because "my pi camera was shorted and burnt a bit from since my pi is showing red light" you do want to go ahead and repair that damage. Anytime you have a shortened component you will have top replace it first and check all of the traces as well as other components which may have shortened out as well. Go ahead and post some good pictures of your Pi5 with your question so we can see what you see.
Since this is physical damage, no firmware update etc. will work for this
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Prasad Gawas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 25
전체 시간: 628
