How to replace power cord?
좋은 질문입니까?
@alienamerican looks like the power cord is available without the switch. That would mean that it is somehow possible to remove the cable from the switch. I wonder if there is a push connector on the switch for the cable. Post some good pictures of your switch etc. with your Question. That way we can see what you see and hopefully come up with a solution. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
Added some photos. This little black box looks like it should open, but nothing I've tried seems to work
@alienamerican what a PITA. I absolutely dislike when they make things so complicated. Yes, it does look like it comes out. The trigger seems to operate some sort of lever that moves the contacts on the inside of the switch. Honestly, at this point I would just cut the wires, solder the new power cord to the tails and apply some heat shrink tubing for insulation.
Good idea. I'm gonna just do that
지난 24시간: 2
지난 7일: 10
지난 30일: 41
전체 시간: 421
